AOS Hard Pipe and Intake Q
I'm in the process of finshing up my headgasket, and while I was down there I figured I would remove the CV at the same time. My question is, once I remove the CV, is there any way I can remove the metal 3 tube supply line(The one with 2 small hoses and one big one). If I can, can I just run a new hose from the AOS to the intake and be done with it? If not, what can I do?
Great walk through. One other quick question which is probably stupid. Does the brake booster check valve need to be inline at the t-fitting on the hose that goes from the brake booster to the manifold, or can I just run 1 long hose without the t fitting and get vacuum supply for that check valve from another source?
I take it you busted the nipple off the T eh? I think laust made a bunch of those out of metal, and they are cheap. Do a search for his vacuum manifolds, it is in one of those posts.
Sorry for the OT question
But Doc could you get me a fairly accurate estimate as to how much 3/4 line I need from the AOS -
the ( J boot -not stock ) that uses a cone filter and fits behind the drivers side headlight ) ?
This hose I found can convey oils well but is like 4.00 a foot. Too little and I have to throw it away too much and its throwing money away ...:-(
Thanks in advance
Regards
Ed
EDIT
Can 5/8 be used instead of 3/4 ? This is Earl's Superstock Hose ...
Its actually 4.85+ a foot for the 3/4 and
3.31 for the 5/8 ....
thx
Thanks in advance
Regards
Ed
EDIT
thx
P.S: Lausts vacuum manifold is awesome, I have one and highly suggest it.
Jane Bond 007
Karl:
I am interested in your writeup but your page won't load. I tried to get it last night and it asked me for a username and password. Am I doing something wrong?
EDIT - Got it. Nevermind
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
