Fuel pressure gauge install
I am going to install a fuel pressure gauge on the end of my fuel rail. What should I use on the threads to keep it from leaking. Will teflon tape work? give me your thoughts on this!
Thanks!
Thanks!
I don't know if you remove that nut recently but mine felt like it was welded.
I would use telflon tape, I always use it
Good luck
regards
Ed
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Good luck
regards
Ed
Thanks!
Thanks!
Part #'s
Take pictures
Originally Posted by testarossa_td
What method?
Part #'s
Take pictures![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Part #'s
Take pictures
I used teflon tape on my install.
You can buy an electrical fuel pressure gauge - it will come with a sender to mount on the end of the rail (or wherever you choose) and a gauge in the cockpit. Is that what you are wondering? They run about $200 give or take...
Heres an ultralite 0-100psi gauge: http://www.egauges.com/vdo_ind.asp?T...ATM-4364&Cart=
