Hotside suggestions... TonyG?
I am going to make a 3" downpipe and exhaust and are going to move to a full garrett spec. What A/R's are people running on a 2.5? Tang divided? I have an inclination for higher HP in mind. Does anyone have housings for sale? I am thinking a .68 A/R may be the go (goal is 400WHP+).
Please only post if you have some experience on this.
I think Edman 951 is running with a .63AR on his
GT30. Speaking of which, why don't you check
www.atpturbo.com. It seems that they have Garrett
hot housings that would fit the KKK flanges. If so it will
save you much time & headache.
I'm running a 58 a'r instead of the 70 a/r, because of the lag on the 70a/r. Depending on the trac you want to use it on, the 70a/r will be to laggy (full boost at 4400rpm instead of 4000rpm).
I unfortunatly don't have a dyno run with the 70a/r, but I woudn't be suprised if my peak HP numbers were up, but torque would be down, due to the lag.
It's sad that Tony's gone from this board
He was very insightful ( pretty opinionated as well ) but that's ok
because he was very knowledgeable
