oil cooler removal
oil cooler removal
What is the best way to get the oil cooler lines off of the housing and what size/style 27mm and 32mm wrenches work best? How about the best source to buy the wrenches? Local Sears doesn't really have a good selection.
TIA, Eric
TIA, Eric
If it helps, 27mm is the same as 1 1/16" and 32mm is 1 1/4". Often Sears will have the standard sizes but not the metric. I lined them up in the store and they were identical so far as I could tell. Those connections proved impossible to remove on my car, so I cut the lines at the fitttings with a razor and replaced them. See here http://members.rennlist.com/tom86951..._seal_repl.htm
