26/6 turbo spool up?
#31
Originally Posted by special tool
Mark - no big deal take them off and weld them man. $60. They are 409 SS and any exhaust shop that does stainless can weld them blindfolded. When its done, wrap them with DEI wrap - it retains more energy than the factory heatshileds.
John -
John -
#34
Mark - it is that easy - takes a little while, but its not brain surgery.
#38
My headers are coming off to re-align my oil cooler housing. I'd like the check/have em checked for leaks... how should I do it. I will wrpa them after.
~Eyal
~Eyal
If you have a k26/6 with 1 bar over 3000, you have a leak. The first place to look would be your cracked headers, or your broken off emission tube.
If your headers are original, they are cracked - simple as that. For any genius who will say, "well, mines ain't cracked", they are cracked under the heat shields, where you can't see it without a cutoff wheel.
You are losing significant power with a leak. The best part of the small turbo is the area under the curve. If I was going to build a stock racer, I would concentrate on tuning the 1 bar spoolup down to 2500.
Let me see how low I can get it on Turbox's car - I am thinking 2300.....muhahahaha
