Why replacing ALL your 20 year old water lines in important (PART 2)
Old 06-17-2005, 07:25 AM
azmi951
azmi951's Avatar
sorry Running. It is finals week and easrly in the morning.
Old 06-17-2005, 10:55 AM
APKhaos
APKhaos's Avatar
We mean: Running tap water in your cooling systems is BAAAD.
Use distilled water - in gallon jugs from your local market.
Old 06-17-2005, 11:46 AM
future
future's Avatar
Is it OK then to run 100% coolant with no water mix or are there disadvantages in doing this?
Old 06-17-2005, 11:51 AM
Porsche-O-Phile
Porsche-O-Phile's Avatar
I've heard the glycol in antifreeze will destroy the clutch plate if it spills in the inspection hole on top of the bell housing.
Old 06-17-2005, 01:13 PM
Ian Carr
That Guy
Ian Carr's Avatar
Hummm...
You think driving for 5 miles in the POURING rain would help wash it off?
Maybe i should go spray the hose in the clutch hosing.
Old 06-17-2005, 02:09 PM
Porsche-O-Phile
Yea, you'd think - but there's that hole conveniently right on top of the bell housing for coolant to get in there. Rain water splashing up would likely not get to that spot due to the body pan and such. . . I wouldn't go hosing out your clutch either, but you might want to check and see how much got in there. I recall someone posting recently what a wise investment it was to put either a metal line, drip / spill pan or plug there to prevent this.
Old 06-17-2005, 06:05 PM
Ian Carr
That Guy
Ian Carr's Avatar
WELL LESS THAN 24 HOURS LATER...
Literally less than 24 hour later one of the very few hoses left that have not bee replaced... Blew out while i went down my driveway.
This weekends project. Replace all old water lines
Old 06-17-2005, 10:50 PM
ehall
ehall's Avatar
You need to bleed your cooling system VERY WELL. The first hose that blew on you also blew on me, and yes, it makes you think HG or something worse. A little air in that system will have hoses popping left and right. Ask me how I know;( I prged the system 6 times, and still had bubbles, but none that I knew about. Really sucked. Anyway, now I have a stant pressure tester. Much better! Good luck w/ the hose fix.
Old 06-18-2005, 12:18 AM
Ian Carr
That Guy
Ian Carr's Avatar
OK so i replaced all the hoses that are on the back side of the motor. So since the rebuild of the motor, 95% of the hoses have been replaced. We bleed the system for a good while today. (i.e. bleeding it once, then letting it sit for a hour or two then bleed again.) we did it about 3 times and there was nothing but water coming out and it doesn't even get to or above the first line on the temp gauge.
I just hope it last this time, and let me say those hoses are tucked in there and you have to break your wrist to get dem boys outa there haha.
Just goes to show that you should replace all your hoses at once
Quick Reply: Why replacing ALL your 20 year old water lines in important (PART 2)
