O Boost, Where Art Thou?
#32
1 Post
Ian; I think so. A shop installed everything for me. Where is the o2 sensor? Downpipe?
John; I'll check.
I have some work to do on afr. I'm too rich up to 3000rpm and too lean from 3000->.
Is this bad enough to hurt spool-up by 1000rpm?
John; I'll check.
#33
First check the items listed above. Cleanup AFR and let's see what you have. Also, you should be doing this in 4th gear. If worried about speed, you can add load by using the brakes (make sure to cool them afterward).
#35
1 Post
This is a test without the boostcontroller. Spool-up to 3000rpm is more or less the same. Spool-up from 3000rpm and up is CRAZY!!!
Sorry John. I let off the throttle as quickly as I could.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#36
20psi at 3500rpm in 3rd gear, and you have not cleaned the AFR is fantastic, isn't it? That's the spoolup characteristics I have been talking about!
Now that you are convinced, that the turbo works as I say. Perhaps it's time to get a dual port WG and start enjoying your toy!
#37
1 Post
Hehe. I was sure you were going to yell at me.
So what is happening here? Why does it boost so quickly from 3000rpm and up with the boostcontroller disconnected? Also, will a DP WG help with spool-up before 3000rpm? I'd love to see 1Bar@3000rpm.
Would I need an EBC to take advantage of the DP WG?
Are we 100% sure that a DP WG will solve my problems?
$350 for a WG and maybe the same for an EBC is a bit of money for me right now.
#40
Wasn't yelling, and wouldn't yell either
I know how the kits work, and the way your car was functioning was not typical. Glad we found the cause!
A DP WW will make a difference, so does cleaning the AFR (we can take the fine tuning off-line).
Before spending money, follow UK952 suggestion.
In 4th gear you can hit 1bar in the 3000-3200rpm (some actually hit 1bar at 2800) but I rather be conservative and you be surprised.
Now would you get me a dyno run?
I would love to see the powerband on your car...
