Largest Tire Size?
The Carnage King
I know Danno got 275's all around on his stock bodied 944 turbo, has anyone put 295's out back? (Fender flaring and die grinding consitutes "stock" body)
My one setup uses 285/30's in the back. No fender rolling, grinding or other nonsense. If I stick with MPSC's when I get new tires I might try a 295/30. Should fit no problem because there is lots of room with the 285's. Front tire is a 265/30, but there is room to go wider as well. I just don't have the rims to do it.
my suspension = not stock
For sure David, my setup is way wider than it needs to be. The car would be quicker around the track on smaller tires. It just wouldn't look as "impressive" sitting still in the paddock!!
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
The Carnage King
Originally Posted by dr pepper
yes she is a beauty - any more pics?
Originally Posted by Mike Buck
For sure David, my setup is way wider than it needs to be. The car would be quicker around the track on smaller tires. It just wouldn't look as "impressive" sitting still in the paddock!! ![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Originally Posted by David Floyd
At what point does bigger... not mean better, even if the size will fit ?
