Limited Slip Diff's How do you identify them without the code number
#32
Originally Posted by Sam Lin
Those of you with aftermarket added LSDs, keep in mind that the Quaife and clutch-type react oppositely to the "turn one wheel" test.
Sam
Sam
#33
It is possible to do a burnout on a 951 with no LSD and still leave to black line on the road. IF the car loads evenly the rear tires, it will do it. I kown, because my car does not have and LSD, and most of the time when lanch hard from a stop, will do that.........For those that think that they may have a clutch-type LSD, get the car in the air, put the trans in neutral, have some one help you by holding one of the rear tires while you try turning the other. If the tire turns freely = No LSD, If the tire doesn't turn or turns very very slowly like if the brakes were apply= clutch-type SLD. I have no experience with Quaife diffs.
#34
Crap, I'm wrong. I read through the service records, and it's a Guard's unit, not a Quaife. Don't know if there's much of a difference. I have no idea if it's a clutch-type, a viscous fluid type, or whatever....
The PO filled the transmission with 80W90 swepco, with no friction modifier. I hope this didn't damage it in any way.
#36
I always test for LSD by putting one wheel on some gravel and one wheel on pavement, sending it up around 3,000 rpm and quickly slipping the clutch. If I hear the left wheel (pavement) squeel and leave a mark I generally assume a state of LS.
