Boost Gauge & Wideband?????
Here's what I bought: http://www.innovatemotorsports.com/x...cat=248&page=1
Sweet aspect in favor of the Innovate:
It can datalog. Not only can it datalog your air/fuel ratio (AFR) FOR 44 MINUTES without the need for a laptop, but it can also record up to 5 other inputs as well when you buy the 'RPM Converter'. I currently log AFR, rpm, throttle position, AFM signal before my S-AFC, and AFM signal after the S-AFC. The fifth input I plan on dedicating to a boost sensor so I can see boost in my logs.
All you do is hit the RECORD button, perform some act of driving insanity, hit RECORD again, drive home, and plug it into your computer using a cable they provide. Computer downloads the log and spits out something similar to this: (legend in the upper right)
Part of the IN Crowd
I just answered my own question.
My MAF will have a piggyback computer of its which is what I would use in place of your S-AFC. Am I right?
