Guru v8 chips + APEXi S-AFC + Innovate Wideband + 18 psi
Old 05-04-2005, 09:11 PM
Dark Lightning
Dark Lightning's Avatar
Default Guru v8 chips + APEXi S-AFC + Innovate Wideband + 18 psi
Just thought I'd toss this out there for comment. I plan on tuning between a 12.0:1 and 12.5:1 AFR. For a modification list (it's almost stock) check out my site.
93 octane, 3rd gear, Guru v8 chips @ 18psi falling to ~13psi by 6500 with no modification to the airflow signal:
Same everything, 2nd & 3rd gear, after some mild tuning:
Old 05-04-2005, 11:00 PM
Mike B
Done With Sidepatch
Mike B's Avatar
Torque, horsepower?
Old 05-04-2005, 11:02 PM
Dark Lightning
No dyno within 300 miles. I'm working on it.
Old 05-05-2005, 12:18 AM
hally
hally's Avatar
looks like you have a nice tuning setup there Dark. How have you routed your o2 sensor cable with the LM? After frying my first tech edge cable, i need to work out a better / cooler way into the cabin than heading back into the engine bay.
Also i notice that your max AFM voltage is about 4.3v which is similiar to that which i got when dialing in my chips for 15psi for a k26/8. I know there was some discussion in the past about what conditions the AFM gets maxed out.
Old 05-05-2005, 04:17 AM
MildMax951
MildMax951's Avatar
Looks promising Dark, I am in the process of doing the same for my Vitesse k26/6 AFM chips but don't have a wideband O2 sensor so the process is a little slower. My initial dyno run on the vitesse chips showed the same trend as your Guru's ie goes very rich at 4000 rpm and stays there. I have Tial and accuboost but I do live at 5000 ft altitude and boost drops to 12 psi absolute by 6000 rpm. As soon as I have dyno results (hopefully today) I will post. Burning your own chips is, how shall I put it , satisfying.
Old 05-05-2005, 07:59 AM
Dark Lightning
I actually zip-tied mine to the fuel lines coming up the middle/passenger side of the firewall. It's warm but not lethal. 10,000 more miles and we'll know for sure.
Now, I need to do some reading but if memory serves the AFM goes up to 5 volts. The DME simply doesn't pay attention after 4.6. That correct?
Old 05-05-2005, 04:48 PM
Dark Lightning
4th gear
I got rid of the 6000 rpm burp.
Old 05-05-2005, 05:24 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Lean out some fuel past 4000rpms to redline.
Old 05-05-2005, 06:22 PM
macnewma
macnewma's Avatar
DL, how significantly is this tuning affecting the proverbial butt-dyno?
Old 05-05-2005, 09:03 PM
hally
hally's Avatar
how about that lean bump at 3200, probably should plane that one down to 13?
I think that the fact that i got the same max AFM voltage at 15psi as you at 18psi suggests that the AFM is maxed out around there in operation, potentially the age / strength of the spring would cause some variation, my AFM is only 12 months old. Maybe if you stick a finger in there and push the door open manually you could get it up closer to 5v, havn't tried it though.
Will have a look at following the fuel lines with sensor cable, thanks for suggestion.
Old 05-05-2005, 09:07 PM
mark944turbo
mark944turbo's Avatar
the max output holding the door open should be 4.6 volts according to the porsche factory manuals. .25 volts closed door.
Old 05-06-2005, 12:18 AM
Dark Lightning
I was pleasantly surprised at the gains; it felt like I went up a pound or two of boost. Now that I'm fine-tuning I don't feel much difference with small changes but I know it'd show if I was on a dyno.
I'm working on that as well. I try +/- a few percent every time I head into town or back home; there just aren't a whole lot of spots to wind out 4th gear, ya know?
Old 05-06-2005, 04:42 AM
MildMax951
MildMax951's Avatar
DL, when I still had a shimmed stock wastegate (only 3mm) and LBE I was getting max boost (18 psi) and max torque at about 3200 rpm measured in 4th gear on a load based chassis dyno (not a Dynojet).
any time you get near any kind of incline in 4th or 5th on the actual road this is achievable. I think you are a bit lean in the peak torque area of a k26/6, the car will go like sh*t but I don't know how safe it is. A lot of 951 tuning myths have been disproven over time, so this may be one of them and you could run for years. Interesting stuff, keep going
Edit:' By will go like sh*t' I mean it will be really quick! (That's a South Africanism and I'm not sure how it translates eleswhere)
Old 05-06-2005, 06:35 AM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
my 26/6 go's like ****. So I understand what you mean about disproving old 951 miths. As more and more people push the envelope and get better at tuning and understanding the car I think products and support will continue to just get better and better
Old 05-06-2005, 07:48 AM
special tool
special tool's Avatar
I couldn't agree more!
Quick Reply: Guru v8 chips + APEXi S-AFC + Innovate Wideband + 18 psi
