New Vitesse "sledgehammer" head - pics inside...
Originally Posted by Dark Lightning
Does Vitesse announce anything on their own these days or is the Tool their elected voicebox? ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Jeff - 16valve is a lot more work.
The "sledgehammer" (
) is bolt-on.
I will have strictly ("sledgehammer" TM) comparison on the mustang dyno within a couple weeks. Nothing else will have been changed.
I am using a long duration, stock lift cam right now.
For those interested - I believe John is currently designing the "Sasquatch" TM head right now - NA core and race only.
Once I get a minute to update the site (any surprises here? LOL) I will post more details and pictures.
For the 951 we will be offering the followings: (you can change the name to whatever you like
- Stage 1 head: refresh, custom seats, stock valve size
- Stage 2 head: Same as stage 1 but with larger intake valves etc..
- Stage 3 head: Different intake, exhaust, keepers,... and larger intake ports as well (SpecialTool special). This requires intake manifold mods as well.
- Stage 4 head: I'm having this done for my race car.. Larger intake, exhaust valves.. many other mods and will be $$$
Notes:
* The intake & exh. valves used on the head (in the pictures here) are totally custom. You will be surprised at the weight in comparison to the stock items.
* A custom cam with the correct lift, duration and overlap will be needed to get the most out of the big-valve head. However there will be gain with the stock cam
* In general, I prefer to have customers do the performance reporting (good or bad!!!).
Notes:
Looks VERY interesting. I'm not knocking it at all - it looks beautiful. I'm just wondering whether it'd be worthwhile to go 16v or just with something like this. No doubt 16v is a lot more work since you have to redo the entire front of the engine, but there's the issue of cost - a 16v head in good condition can be had for about 500 bucks. This bad boy is going to be (I'm guessing) at least a grand and a half. . .
The flow rates on the sledgehammer might actually be better than with a stock 16v though. . . It's got definite possibilities.
The 16-V head will flow better than any 8V head, and is much more timing friendly. However, a used 16V head in fair condition is about $1000 then you have to replace the valves add about $1-1.5K, rework the head etc , exhaust manifold, intake manifold and you will be looking at an easy $3.5-5K.
If money is no object, then 16V might perform better, however it might require more maintenance as well...
I'm with Vitesse. 16V will dominate but on a dollar-per-horsepower chart an oversized 8V will be superior.
My only concern over an extremely oversized 8V head (or 16V for that matter) is this: if the valves are too close to the edge of the combustion chamber & cylinder wall you'll actually start to see a drop in airflow potential.
Location: Dallas, then Annapolis - now Laguna Beach CA. Well, not so fast - I'm back in Dallas. For good!
However much HP it makes, I don't believe you... lol
Had to do it.
I kill myself sometimes...
Had to do it.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Of course, valve size is just 1 factor, there are lots of tricks that can take place. Then again it's all $$$. Once you go over a certain level, the gain per $ goes down fast. You got to find a sweet spot and call it the day.
I'm not an expert, but has there been a little metal removed near the valves? Does that create increased "squish area" volume with a subsequent change in comp ratio?
