Check your injector wires !
It was running on 3 cylinders after I had just installed a new clutch and turbo upgrade, so I was checking over things and wiggled the #2 injector wire and she started running on all 4 cylinders.
I have new connectors on order and will be making a new injector harness.
Originally Posted by theedge
Im just waiting for those 951 rebuild harness' to go one sale from 928 racing ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Originally Posted by David Floyd
I'm watching that thread, for now I need something quicker, $19 for 4 connectors and a little construction time ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
David
Where are you getting the connectors?
I'm having similiar problems with other under hood connectors and was thinking
of making a new under hood wire harness.
I had a post about a month ago or so about rebuilding the fuel injector wiring harness...i had the exact same problem as david. Parts are readily available from napa.
Thefu
I had the exact same problem a few years back. Sourced all the boots and connectors from the dealer. The only part I couldn't find was the boot for the AFM plug. I posted the part numbers some time ago. I have no idea if that post is still available.
Rennlist Lifetime Member
Same problem here. I think a mandatory connector check should be on the list for all new 951 owners, since literally every connector in my engine bay needed to be re-wired or otherwise repaired.
A simple check with a multimeter should tell you where your connectors are shorting out.
I removed the other connectors this weekend, while the 1 pictured was really bad, 3 of the 4 were bad.
New connectors will be here tomorrow.
