Wideband connection to AFM Link ?
"****, just re-read this after getting your email (thanks for the template btw) - you really DO mean the AFM-in line don't you! "
Yeah, the AFM-IN line datalogs a 0-5v signal, the O2-sensor line only datalogs the standard O2 0-1v signal. With the template that Jake951 worked up, you can graph and compare the wideband vs. standard-O2's curves. You'll find that if you do three full-throttle runs, the 3rd one on the standard-O2 sensor actually matches the wideband pretty well.
Originally Posted by Mike S
That's why I put my wife in the passenger seat! :-) But I think she's getting tired of full boost runs down the street. LOL!
Regarding dialing in the system, you really need the data logging capacity of the link system or you will be paying dearly at the dyno. There is a learning curve associated with the system. Further, it is far better to have it closely dialed in before going to the dyno so all you are doing there is fine-tuning.
There is too much guesswork to figure out what cell the system is in at times. Last week I was helping Jason with his Link and his idle was the exact same as mine. That is the hand held stating that it was idling in zone 305 but cells 300, 205 and 405 actually affected his idle. Also, if you have no idea what zones the system uses for starting hot starts are a real pain. We were unable to use the data logging function, as Jason hasn’t fully installed his system (Jason whenever your really call)
My experience is WOT air/fuel ratios comes very easily. The hell is with the part throttle and off idle response, dependability and support. ed
However, using the search facility, I found a brief discussion on whether it is as simple as that, or if the voltage has been scaled so that 5v would equate to 255. Was that question resolved?
Regards
Graham
'88 Turbo S
Ed, I've been meaning to drop an email to you, just been a very busy weekend/week as my parents are visiting. I anticipate being good to go mid-next week. I can't say enough how much I appreciate your help, and having played with the hand held tuner myself and then watching Ed work with the serial link, I would strongly recommend it - he's completely right, there were so many other factors aside from the cells I was working in that I can't imagine being able to get the a/f accurate for partial throttle driving without the serial and the datalogging capability.
mark944turbo,
per your diagram, I'm assuming that I should be logging Vout which is pin #1?
Does anyone have a screen shot or two of what the serial link software looks like. The PC Link software is the only thing that I can find on the LINK website and my understanding is that this only works with the newer Link units and not the AFMLink.
"However, using the search facility, I found a brief discussion on whether it is as simple as that, or if the voltage has been scaled so that 5v would equate to 255. Was that question resolved? "
Yes, that 0-5v range is scaled across an 8-bit number. Take Jake951's template and divide the AFM-IN column by 51.
Mike, sent you an email.
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
