mpg of 400hp?
UAE Rennlist Ambassador
Originally Posted by Konstantin
btw the price of gas is here 1.69 US $ per Quart (not per gallon)
Konstantin
Konstantin
Overhear its now € 1,34 for one liter that would be € 5.15 one US Gallon ? That is $ 6.18 This week was the first time i had to pay € 100 for a full tank.
I'd imagine just because you CAN make 400 h.p. doesn't mean you need to all the time. Heck, my 944 gets 28+ mpg if I drive it like an old lady - it's just a four-banger after all! Even a 400 h.p. motor should make well over 22 (I'm guessing) if driven very conservatively. Of course getting on the loud pedal will cause that number to plummet quickly.
Spell Checker
$2.50/gallon here in florida. As least that is what it was last night. It is more expensive here in Gainesville because of the taxes (there is no other income except for purchases from students).
If you've got a MAF/MAP setup, test pipe, big turbo and lots of boost, it's already pretty close to 400hp (crank). I can't see any of those significantly lowering the MPG if the car is driven conservatively. Of course when you're using all of the power, it gets worse - which is pretty logical, given that the power comes from burning gasoline.
I'm nowhere near that HP level, and I'm getting about 15 MPG driving around the town. Then again, I didn't get the car to save fuel... and of course, at the track I get around 8-10 MPG
The beauty of a turbo is that all (or almost all) of your modifications aren't active while driving with cruise control; they only show up under heavy throttle. For this reason modified turbo cars typically see the same gas mileage as stock.
I was nearing 500hp in my previous car and still saw 28-30mpg on the freeway if I behaved.
How bad was it with my foot to the floor? Well, some quick math says that I burned about 3/4 of a gallon of gas for every 60 seconds of wide open throttle. What is that in mpg? Pshh, it ain't good but damn was it fun. That's all I know.
