top end rebuild
top end rebuild
Hi, all
In my ongoing(and, sadly, long) quest for 951 I have two questions:
What is the difference between top end rebuild and complete rebuild. What doesn't get rebuilt in top end rebuild? (just don't say bottom end , a little more details please). When top end rebuild is enough and when a complete one is required?
Also, is difference between 951S and 951 engine is just bigger turbo or engine itself is a little different, reinforced or something?
thanks in advance
Alex
thanks in advance
Alex
Alex~
A top end rebuild will include having the head worked, doing belts, rollers, lifters, seals, and the typical wear items above the block. A total rebuild will go a step further and include rings, bearings, and the time to haver a machine shop go over everything in the engine.
A top end rebuild is done when the timing belt goes, bad lifter noise, low compression, etc. A full rebuild is done when a car starts to get up there in mileage, or it spins a bearing.
I am not sure about the diff. between a 951 and 951s motor, the do have a bigger turbo, but past that?
~Eric
~Eric
