MBC Test A Success!
MBC Test A Success!
Thanks for all the good advice Rennlist! As the attached pix show, I took a stab at a test fix on my overboost fuel cut off. Placed the Lindsey Dual Port Manual Boost Controller in line between the previously plugged line off the IC pipe banjo bolt and found a handy place next to the windshield washer bottle to secure the controller temporarily.
Using only a screw driver and a pair of scissors, a mechanical miracle has occured. Perfect fix for $60! At full throttle, the 89 Turbo rockets through 2nd and 3rd, with factory boost needle bouncing off 2 bar, immediately settling at 1.75 - 1.8 and staying there all the way to the red line.
All good. As soon as the boost gauge, AF meter and panel arrive, I'll stick the boost controller in the cockpit and replumb the rig more cleanly so I can tempt myself more often with the other worldlish Power Of The Boost.
