Turbo Removal Questions
After you remove those pesky bolts, you should switch to regular hex bolts like I did. Hopefully removing them this time will be a lot easier.
Jeez I never thought of that ...
Thanks to z3bra I bought these 12 hardness bolts ...but they are still socket type bolts....
BTW I have quite a few extras if need by anyone ( both long and short )
rregards
Ed
rregards
Ed
rregards
Ed
rregards
Ed
Anti-Sieze when you put them back in !!!
1 Post
Snip...
You have to remove the down pipe and the turbo to cat pipe
-John
1 Post
ALSO
I wanted to add that you should be pushing, as hard up into those bolts with thw allen socket as you
are trying to turn the wrench
-John
Yes my mistake ... I should have said its all comes out together
but it has to be disconnected from the crossover
The easier alternative might be to drill the center housing of the turbo's threaded holes and helicoil it to 5/16 x 24 at which point you could use a reduced head version of an AN5-51 aircraft bolt. (Don't have the part # handy but it's probably a NAS bolt anyway in A286). That's honestly the best option to get the best material for the application. Unfortunately the thought of rethreading the center section of the turbo doesn't thrill me nor does using imperial measurement crap, but the logistics of the aerospace industry mean that imperial measurement based fasteners probably aren't going anywhere in the forseeable future. As I understand it, it would basically cost a fortune to recertify everything into metric equivalents. Really a shame although hopefully with most american cars using metric fasteners now too there might be a faint glimmer of hope at least. On the upside, regular aerospace bolts are significantly less expensive than metric ones. (hell they're still probably cheaper than 22+ bucks for the long turbo bolt from the dealer).
If you went to studs you could most likely use some MS21042-5 self locking "jet nuts" or an H20-5 12 point locknut. They're pretty reasonable at under a couple bucks each. Arguably with some halfway decent studs you wouldn't even need to get A286 for the studs since you're not faced with stripping out the internal socket's hex, it still wouldn't hurt as the application lends itself to corrosion with the temperatures of the turbo. Probably overkill but you'd never again have to worry about stripping those damn things out and I think that's something we all like the idea of. Might also make it so less things need to be removed to pull the turbo as a standard 12 point socket could get in there with a universal joint. Hmm I'm liking the idea of rethreading the center housing more and more.
z3bra,
Well I just found some bolts in the hex design that looked the same length of the original mounting bolts. Now that I think of it though, I probably should have used a washer between the mount and the bolt head. Maybe thats why its leaking oil in the first place?
That could definitely cause you to leak oil if the o-ring under the bearing housing doesn't have enough pressure applied evenly to seal properly. I had to special order the bolts at about 2 bucks each just for the standard grade 12.9 metric ones. I've been trying to dig up some 5/16" A286 rod to make some studs instead as I think combined with some all metal lock nuts like I mentioned earlier that would be the easiest way to go about rethinking the maintainence problem the Porsche engineers were kind enough to throw in our laps. I'll just get some 8x1.25 cheapie threaded rod and test fit it but if that fits ok then I'll probably take the plunge and switch it over to studs for good. Again I'm not thrilled about chucking the metric for fractional fasteners but I can make threaded studs pretty easy and finding reduced diameter metric nuts is tough.
