tension for all belts
I never notice, anyway
i replaced all my belts a little while ago and have a little whine up front, on the front of the motor, more toward the passenger side. the krikit tool gets constant 28 lbs on the balance belt, though, which is what i would have suspected would have caused the whine. i know the timing belt should be at 40 lbs, but what should the power steering and alternator belts be tensioned to?
I have the power steering set at 30lbs and the alternator/ac compressor belt set at 80lbs, but i do remember seeing the manual stating the a/c compressor/alternator belt should be at 9.2 or something (never went back to check).
Someone correct me on this but off the top of my head I believe the "new" balance shaft belts (part # ending in "04") get tensioned to 35, not 28 and the old ones (part # ending in "02") get tensioned to 28. Maybe this is part of the problem?
well yeah, i guess that can be true if theyre way undertensioned - my alternator belt squeaked until i tightened it. but your timing and balance belts won't make noise if theyre undertensioned.
