Mahle 100.5 and 101mm Pistons
#36
according to the book, yes, both were offered. That's what I meant when I stated that the person I talked to had both drawings in the book on his desk.
#37
email sent...
Christian,
Here is just the support over the weekend and only from 1 forum. Price seems to be the main concern for all parties. I KNOW, almost 100%, that the response would be the same on the 968 and 928 forums for their perspective pistons (oversize) as well. I hope it peaks your interest and those above you at Mahle.
Regards
Bret
https://rennlist.com/forums/showthread.php?t=193322
Christian,
Regards
Bret
#39
Originally Posted by Ski
email sent...
#40
Let's hope Mahle comes through with a set or two that can be used in our blocks. I guess I read something wrong about the silicon matrix only being so deep as no one else remembers reading it.
Dan
#41
Sorry Bret- missed your input on the 101's.... I was just asking b/c several other's had pointed it out...
Dan- I swear I think my PET shows both, but, will have to look soon- I can't load it on my regular comp b/c I'm running XP- I'm wanting to get 2000 loaded on here too so I can run either one when I want, but, until then, I have an old POS laptop I can occasionally use to bring PET up.... PITFA, but hey....
Bret- are you just outside of Nashville or something? I'm just curious b/c of your sig? what suspension mods have you done? IF you are in Nashville, I'd love to get together one day & check out your car- I'm debating over all kinds of things for mine... having all kinds of probs too...
#42
Condo in Germantown(Memphis), home in Heber Springs just off the lake.
968 bars w/delrin bushings, Firehawk struts, 250# and Bilstien sport shocks on the rear, full coil over kit is coming this fall/winter when I install the new engine, disassemble the car and full repaint.
Robby did you buy a car in Springdale AR?
#43
OHHHHHH..... THAAAAAT Germantown...... I was thinking of the mythical NASHVILLE-Germantown..... Anyway..... I think I need to get a little Atlanta-meet together to try a few dif cars.... What are Bilstein "Sports"? Also, how do you think the Bilsteins FEEL on the street? Do they feel comfortable w/those springs or do you think you needed slightly stiffer springs, or, do you think koni DBL adj might be more comfortable? Any suggestions would be appreciated- I was planning on Firehawks all around- was told I needed more in the 275 - 300 range- Cervelli had always said 250 was a minimum for those. How are the delrin bushings? Do they squeek or anything? Did they make the ride any rougher? Not sure how they would, but.....
Sorry for the tangent- YES- I AM intersted in the 101's... I'm planning a rebuild soon- would those 101's work w/968 crank for 2.8L stroker? I'm really hoping to get by w/out any boring work at all- I HATE the idea of having my block machined, but, if I go any larger, I will go straight to 101's, assuming the alusil coating is all the way down into the full 1mm....??? THAT scares me a little too.... of crouse, if it's a full .5mm, then, that should be alright- .5mm all the way around would be 1mm worth of diameter, right...? I need more $$$.....
No, I bought my car in Norfolk- October 13 1999....
#44
Jim, jwl on here, had 101 2.8L pistons done with Tom C, he will pick up his block and mine tomorrow; he is building a 2.8 stroker, I doing an almost 2.6 (2532cc)
