Intake vacume Bolt
Ok how do I remove the vacuum bolt where the klr line connects to the manifold, the one in between the 3-4 runners? Trying to install Laust's 5 port manifold
It unbolts just like a normal bolt would, although it may take a good bit of force to get it moving initially. Make sure you don't loose the little washers/spacers that go between everything. I dropped on down under the intake and it was a pain to get out.
