Found out why my clutch was slipping !
03-12-2005 | 08:30 PM
Some may remember, I went to the dyno end of last year for final tuning, but had clutch slipping problems.
I guess a cracked pressure plate would cause that !
8 k easy miles on the clutch and pp
03-12-2005 | 08:32 PM
03-12-2005 | 08:38 PM
Well at least the release bearing and disc are still good
03-12-2005 | 08:45 PM
ST, KEP came to mind... is that what you are using ?
Zero10, disc is shot, glazed over.. nice blue hot spots on the pp and flywheel also, release bearing seems ok
03-12-2005 | 08:49 PM
Yeah. And I think you said you were going to use copper/ceramic too a while back. This is what I have(6 puc, solid hub) - it is fine on the street for a little bit with no traffic.
03-12-2005 | 08:52 PM
Yes, I have a spring centered 6 puck, thought I was going to reuse the pp.. NOT !!
03-12-2005 | 08:56 PM
KEP here also... Where did you get the 6 puck spring centre from David?
03-12-2005 | 09:02 PM
03-12-2005 | 09:06 PM
03-12-2005 | 09:17 PM
Quote:
Originally Posted by NZ951
Did you get the 18702?
Yes, Racing 6 Button "E-Z LOCK PRO" ™ Sprung Hub
