Lindsey bov
#46
[QUOTE=RobNL]That's good news. We all want a bypass valve that is able to reduce spool time. But how can you measure time in rpms or are you talking about changing the boost threshold?
Tim, if the air is charged against the bottom of the valve, shouldn't the vacuum/boost line create the same pressure on the opposite side of the valve?
Yes.However, the charge air could force the valve to open prematurely this way.If the charge air is coming in from the side(like the stock unit) it cannot open the valve.
