550cc injectors and how much hp
Is there somewhere that can tell me if 550cc seimens injectors can support 300 to 325 rwhp and at what duty cycles? What lb's/hour would these convert to? I come up with 52.38#. is this correct?
I must be doing something wrong with these calculations!!! I'm running 3 bar rail pressure. with the intent of a maximum 500hp at the crank (about 23-25psi I think) from 4 clyinders. The website suggests I need 93lb/hr injectors to run at 80% efficiency!!! Not good because I was only fitting 55lb/hr!!
Ben
Ben
I have seen those calculators before. They all say I need 75 to 90 lb injectors. I know people run 52 to 55# injectors for around 360 at the crank which is what i am shooting for ( 300 to 320 at he wheels).
I'v just been very relaibly informed that the calculations are wrong. Andrew Sweetenham who used to own a very nice example 2.8lt 944 turbo with 422hp at the crank. He was running 55lb/hr injectors and told me they had plenty of capacity spare. I would trust his opinion and use 55lb/hr.
Ben
Ben
