I am in need of help asap Jack Points
I have jacked this car up many times but not on all 4 jack points
I use the frame rails in the front BUT what are the points in the rear ?
I don't like the ones in front or the rear wheels....
I have heard some say use the torsion bar holders ???
I did a search but it seems if the post is from long ago the pics are not there
I just want to start the F#$@ job !!
\Please help
Thanks Guys
Regards
Ed
\Please help
Thanks Guys
Regards
Ed
You can jack the tranny (right under the round diff section) if you're trying to raise the entire rear. Then put jackstands on the torsion bar tube, one on each side.
Sam
Sam
Look behind the rear wheels, right up almost in the bumper corners. Theres one in each corner that look like the front ones. On turbos they are tucked in the corners of the rear under spoiler.
Thanks Sam. Jeff and Brian .. So much
I used the ones in front of the rear wheel for now but I used a piece of hard wood flooring as a buffer.
In the front I used the 2 beams and the 2 front donuts ( a big mistake ) one is already 1/2 pushed in.
I will change out the rears tomorrow ... What a waste of time not to mention almost killing myself
I now have 6 jack stands I may just pick up another pair and put them on the rear bars
Thanks for your quick response ...
Regards
Ed
Regards
Ed
Thanks Andre
regards
Ed
regards
Ed
