The Block has arrived!
REALLY stupid question, but what is the significance of all the little holes drilled into the sleeves? They look too small and irregular for coolant or oil flow; does it have something to do with controlling the shape of the bore as it expands or something?
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
1) The 2.5 sleeves will ‘only’ go to 104mm, the 3.0 sleeves will go to 106mm.
2) The holes at the end sleeves do line up with the coolant holes in the head gasket.
3) No valve notches are needed for stock compression/stock cam. They can be added if needed – but the less sharp edges the better (prevents hot spots the encourage detonation)
4) the Honda Darton Sleeves similar to these are run to past 30 lbs regularly….
Chris White
Chris White
I want to chime in with a "Very impressive!" With a new turbo engine nearly completed based on a new 3ltr block I was not aware of this option 2 months ago or I'd have probably gone this route too!
Pretty work Chris!
Dan
Pretty work Chris!
Dan
Originally Posted by WesM951
So this would be considered a 2.8L then correct?
106mm, stock crank = 2.758 ltr
so... neither is "really" a 2.8
Joe, I must say you are the MAN !!! 20 years old, building a kick a$$ engine and an impressive house at the same time.
