Supra doing 36psi on the Dyno
#35
Yeah, I did as well. Anyone can do it. Depends how much det you want. At 17 degrees and 18.5 psi, anymore timing will get some det on my setup. This is by using the Knock Block. So its basically as good as you get det monitoring wise.
#38
UAE Rennlist Ambassador
Laust: What i meant was you going back and reading the archives hence me saying "are you bored" LOL
You should know a lot about high boost on 951's though
#39
Figured I would toss in this fact for anyone interested...
Promotion Racing ran either 32 or 37 psi, I forget which it was, on a very well tuned and built engine (internals and the whole schebang) and cracked the block!
EDIT: I will get more information on this if anyone is interested.
