Need help with conversion from ARC-HR to PSC1-003
Hi Guys:
I am getting rid of my ARC2-HR (also known as ARC-A on www.splitsec.com). I believe the unit has a problem and tuning is also much easier and flexible with the PSC1.
Here are the ARC-HR connections as it is on my car right now:
Loom #1: Red, White, Black
Red – Switched Battery Positive (+12V) [On with ignition switch]
White – Instrument Panel Light (+12V @ dash lights) [On with dash lights]
Black – Battery Negative (-12V) [Chassis ground]
Loom #2: Violet, Grey, Yellow
Violet – ECU Signal Input (Connect to Green wire w/red stripe on DME harness terminal #7 using ‘piggy back’ connector)
Grey – ECU Temperature Input (Connect to Green wire on DME harness terminal #22 using ‘piggy back’ connector)
Yellow – Throttle Position Switch Signal Output (Connect to White wire with Black stripe on DME terminal #2 using ‘piggy back’ connector)
Loom #3: Red, Black, Brown, Green
Red – MAF Power Supply (Connect to Red wire of MAF loom)
Black – MAF Ground Supply (Connect to Black of wire of MAF loom)
Brown – MAF Signal Ground (Connect to Brown wire of MAF loom)
Green – MAF Signal Positive (Connect to Green wire of MAF loom)
Please check
http://www.splitsec.com/
under products and see what connections they recommend for the PSC1-003.
1.
Which of the recommended connections should I use?
2.
How should I connect loom #3 coming from the MAF sensor?
Red – MAF Power Supply (Connect to DME #18 red/yellow stripe)
Black – MAF Ground Supply (Connect to DME #17 brown/yellow stripe)
Brown – MAF Signal Ground (to # 17 as well ????)
Green – MAF Signal Positive (is this the MAF sensor output? - green wire of PSC1-003)
Thanks in advance!
Please check
1.
2.
Thanks in advance!
