Flywheel Pin for Reference Sensor
While replacing my clutch, I managed to damage the little screw-in pin on my flywheel. Can I use any ole bolt to replace this pin? Assuming of course I set the proper height for the reference sensor. Has anyone had any luck using something other than the stock pin? Or would I be better off just ordering a replacement pin? Thanks in advance
It's just a metric screw with a allen head. Take it to any big hardware store and you should be able to find a replacement, get steeel and you should be able to find one in San Antonio - and if you ever need any block work, milling and such in San Antonio, Duffin Engine is great! Loctite it and set it to 5mm IIRC.
