Change of situation... help needed
I posted a week ago on how when the car was cold and i tried to drive it i would get a screeching noise and it was the belt rubbing the housing or whatever ill fix it soon. Well yesterday i had the defrost going and the car was warm as hell and it was still screeching.... turned the defrost off.... screeching goes away. Defrost on = screeching noise when driving...... defrost off = no screeching
hmmmmmmmmmmm?
Thanx, Mark
hmmmmmmmmmmm?
Thanx, Mark
Sure sounds like the A/C belt to me too.
When you say defrost on, you mean the defrost button on the climate control? If so, that turns the A/C on, and would make this guess even more plausible.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
It is more correctly referred to as the A/C – Alternator belt, hence the squealing under heavy electrical and A/C load.
Retention it from below – but make sure you loosen all the A/C mounting bolts before cranking of the tensioner rod.
Chris White
Chris White
