Ignition Map
01-31-2005 | 03:19 AM
Ignition Map
Anyone have specs on the stock ignition timing maps, both part throttle and full load they can post?
01-31-2005 | 03:32 AM
I have mine in my Link, but I am not sure thats what you want.
01-31-2005 | 02:15 PM
Ask and ye shall receive (courtesy of our fellow 'lister Rob):
01-31-2005 | 07:39 PM
Whats on the x axis? MAP? I dont get the % though...
01-31-2005 | 08:10 PM
Load. Can be seen as an approximation of MAP. More correctly I guess it would be mass of air in the cylinder.
01-31-2005 | 08:16 PM
01-31-2005 | 08:19 PM
Quote:
Russ,
Could I have the timing and fuel maps for a 500bhp with K26/8
01-31-2005 | 08:31 PM
Since his talking about % I reckon NZ is talking about the y-axis?
01-31-2005 | 09:29 PM
My guess would be that the Y-axis is throttle position (TPS) and believe that it uses a different map above 60%.
01-31-2005 | 09:37 PM
Exactly what I was looking for...Thanks very much
01-31-2005 | 09:48 PM
No Laust, the DME doesnt have TPS info so that's impossible.
I'm quite positive it's what Bosch calls load which basically should be air flow/rpm.
01-31-2005 | 10:11 PM
Thomas, OK I primed my post with "guess" since I knew I was on thin ice, but how come the "load" only goes to 60% here?
01-31-2005 | 10:28 PM
Over %60 load would have to be one of the triggers for transitioning from the PT map to the full throttle map.
01-31-2005 | 11:19 PM
These are good questions. I know for a fact that the DME chip will use the "full load maps" if and only if throttle is more than 65 degrees open, according to factory manuals. The %s are definately load percents, I am currently trying to convert these numbers to psi but it is difficult. They appear to be arbitrary numbers derived from airflow (per afm) per rpm.
01-31-2005 | 11:57 PM
Yes I meant y axis.
FWIW my timing is much more aggressive than that map. But I cant tell the load and how to compare it.
