Lindsey Super 75: It keeps pulling and pulling and pulling...
#61
Drive-by provocation guy
Hey ALpine!! Ouch!!
I actually spent the winter of 94 in western Mass, Ft. Devens. Had 121 inches of snow that year.
I was actually washing and waxing my car this weekend with shorts and no t shirt
Although we have been in the 30's numerous times this year.
#62
UAE Rennlist Ambassador
Originally Posted by toddk911
Yep!
Got them for Xmas, but wit hall this crap they are still sitting in the garage.
And part of me is scared to tackle it as I just got the car abck and don;t want it to be down for another month for instal or tuning problems
I will get to in the next couple of weeks probably. After Rolex.
AFM
LR Turbo
GURU WG
GURU Chips
hmmm.......i have a feeling something is terribly wrong somewhere......
A note, when you get 'new' chips, you do know that they are tuned for the AFM. After installing the MAF, you would need MAF chips to "set it right"......
Anyways, i know a couple of people running the LR S75 getting full spool (1bar) @ ~3,300 or so, but they have a MAF installed.......so i guess that makes sense with regards to you're 'late' spool.........
#63
"So your current setup is:
AFM
LR Turbo
GURU WG
GURU Chips"
Yep!
"hmmm.......i have a feeling something is terribly wrong somewhere"
How so?
"Anyways, i know a couple of people running the LR S75 getting full spool (1bar) @ ~3,300 or so, but they have a MAF installed.......so i guess that makes sense with regards to you're 'late' spoo"
I hope so. And I will have chips that are a little leaner down low to help spool up.
Also Hos, yo unever told me exactly how to test when full boost is coming on and in what gear ?
AFM
LR Turbo
GURU WG
GURU Chips"
Yep!
How so?
#65
How so?
Simple, you cannot have chips burned for you and set 'right' because of the 'mystery' turbo, and now you installed a different turbocharger, thus the chips are not tuned for it......
Originally Posted by NZ951
How is a MAF going to reduce spool by a few hundred rpm?
#67
posted by NZ951: How is a MAF going to reduce spool by a few hundred rpm?
AMAF can push you to 3200 rpm with his skinny leggs and then your turbo will take over from there.
#69
The barn door can flow I think enough air for around 400HP. I still dont see how a MAF reduces spool.
Hosrom, do you have evidence of a reduced few hundred rpm in spool after MAF install?
#70
Well that goes without saying...
#71
It's true; MAF reduces spool up. With a low restiction intake before the turbo, the compressor "grabs" the air easier.
NZ,
the stock AFM can't flow enough for 400 hp. Well it can, but very inefficiently, too much pressure drop between the barn door and the compressor inlet.
NZ,
#72
Monkeys Removed by Request
My spool up dropped several hundred rpm after my maf but, to be fair I also had exhaust installed and the car retuned so that prolly had something to do with it to. Maf will reduce spool up the question is how much?
Before my mods and 13psi was like 3650 or so after was like 3250. Ofcourse then I dialed it up I was getting like 16 at 3500 and 18-19 at 3800. Although I believe I was in 3rd gear not 4th....in 4th the times would be dropped some...how much exactly again I dont know for sure. I will do a test of my 26 tomorrow in spool up differencies between 3rd and 4th and see what I get.
#73
Both MAP and MAF vendors have proof of spool time dropping with their systems.........
MAF users (above) also gave their input on this with regards to MAF aiding in spool.............
#74
Hosrum,
I hate to say this but please don't post any 'quotes" if
you yourself have no direct experience with it.
Regarding the Kokeln 363 kit. Someone here bought
the whole kit & did not even make 330 rwhp after
dyno tuning. So, please unless you've seen it or have
done it, dont speculate.
#75
Originally Posted by J Chen
Hosrum,
Heads up: That 'someone' didn't get the power that Koklen mentioned may/may not had the cam that should be also purchased? aka songzz?
Never the less, in your own words:
IIRC: I didn't "speculate" anything.........
