Should I Port/Polish My 951 Head?
#31
Originally Posted by M758
Hmm,
So if the port is too big... you need to make it smaller.
So... how do you make it smaller? Can you install a coating and then machine the the coating to the proper shape? Sleeve it?
Why did they make it so big anyway?
#32
Skunk,
My 2.5 T head vs 2.7 N/A head have drastically different intake ports - turbo being round and N/A being oval.
I measured my 2.5 port and got dimensions of approx 40.15mm at the opening and 47.2mm at the largest point. The 2.7 has an opening of 49.20 and it transitions to the largest point of 58.01.
That's a big difference in size and considering your comment about the 951 intake port being large enough to accomodate a 3.2L engine, why do you think Porsche would increase the port size and shape on a cylinder head for an engine with only .2L increase in displacement compared to the 951?
Jeremy,
The 968 T w/ 8 valve used a different cylinder head that had smaller exhaust ports compared to the 2.7 N/A - not sure if was it had ceramic liner or not.
Jeremy,
#33
Originally Posted by Jeremy Himsel
Does the 2.7L NA head flow enough to support a 3.0L T application or would “hogging it out” be beneficial?
Additionally I would love to see some real data on how much gain or loss in spool would be found not using the ceramic liners in the exhaust port. While I can see the intent of the liners, especially with the distance between the turbo and the head,
#34
Originally Posted by Pauerman
Skunk,
#35
Skunk,
I'd be interested in knowing how you measure your VE.
125% VE means you have 25% more air molecules than would otherwise occupy a fixed volume (cylinder). The only way that can happen is if the pressure goes up by 25%.
That would mean that on a NA engine that has 14.7 psi absolute pressure available (at sea level, for example), there would be an effective static pressure of 18.4 psi when the intake valve just closes.
On a turbo car that runs 12 psi boost ( 26.7 psi absolute), the pressure achieved in the cylinder would be 33.4 psi. That would be like achieving actually over 18 psi boost because you have a VE of 125%.
Sorry, I don't believe this for a second.
#36
Originally Posted by Skunk Workz
49.2 in width,I guess...what height,with it being oval? Haven't measured any of the 2.7NA's,they're not really common over here....
#37
Originally Posted by TurboTommy
Skunk,
#38
On either side of the injector cut out the port measures 40mm vertically. The vertical section of the port tapers gradually smaller until the base of the guide.
#39
Ok...so if you compare the cross-sectional area of the two ports at a point just before the valve guide,what do you get? Which port has the smallest cross-section? The round NA-port is about 47mm in dia...this is about 1735 square millimeters...what is it for the 2.7's oval port?
Don't know if this is right, but since the port is oval I averaged out the sum of both cross sectional areas and came up with 1775 square millimeters.
#41
On the 951 port, if you consider 47mm to be the diameter at the largest point w/out considering the area lost from the hump in the casting before the guide, the best vertical measurement I can get on the oval port is 34mm. The hump in the casting for the guide begins much sooner in the oval port compared to the round port. So, measuring before the guide, I found a width of 58mm and a height of 34mm on either side of the casting hump.
#42
The question still stands:
How are you measuring? How do you know you're achieving 125% VE?
#44
Originally Posted by Ben Z.
Do any of these flow/velocity arguments apply to the exhaust side of the equation?
#45
That means that for an increase in size from 2.5 to 2.7 liters you just have an increase of 2.5% port area compared to the 8% displacement increase...the port is smaller relative to cc's.
I remeasured my 951 port and figured 46.5 mm as the average diameter so that equals 1720 square millimeters.
So according to my measurements it seems that the 2.7 oval intake port has approx 8% smaller cross sectional area just in front of the guide compared to the 951 intake port.
Skunk, this decrease in cross sectional area will contirbute to increasing the velocity of the intake charge right? Given these measurements, do you think the port sizing on the 2.7 N/A head is any better matched for a 3.0L turbo application compared to the 951 port and its 2.5L displacement?
