What do you guys think? (intake off with pics)
#61
UAE Rennlist Ambassador
Laust: Yes, they are out (look on page 2 or 3 for how much was under there)
Perry951: Those fuel lines may look bad due to dirt, but it may/may not be replaced by the PO. Anyways, the intake is back on and CV is shot (shout out to Rob for this) but i am adressing the fuel lines next month (student + finances = limited budget).
#63
You mentioned an intake manifold vacuum line update kit from LR that replaces the old stuff, but I can't find that on their website. Can you point me to it, or at least tell me what category it's in? Their website isn't the easiest to naviagate...
Matt, If you put idle stabalizer or venturi into the Search, it pulls up the hose kit.
It doesn't get much easier then that!
Wes
Wes
#64
Andy,
Take off that pic!!! DONT compare both my car and yours!!! besides, you also have many brackets removed and don't live in a desert
Wes: Here is post 3 for LR Venturi: (click on intake, then miscellaneous)
http://www.lindseyracing.com/Merchan...KEMANIFOLDMISC
PS it is not a LR kit, its just the updated OEM hoses LR sells. Unlike THEIR vacuum line kit.........
#66
Okay, i said their KIT which also includes 5 brass T fittings (where i used 1, thanks to Laust's new invention), i didn't say that they manufacture ever piece of it did i?
#68
Hosrom,
Is the samco hose I bought and brass T's from a local fittings shop now the NZ951 kit? Or is it still samco's hose? Thats the point I am trying to make.
Raagi,
The hose is I think dash 10. It just fits over the AOS, but I made a made connector piece. It fits perfectly on the can. I got my hose from Scralets and Waterloo Rd. But you can get it at most any hose shop, the only thing is that the dash 10 size does not seem to be consistent between manufacturers.
Raagi,
#70
Originally Posted by NZ951
Hosrom,
Originally Posted by black944 turbo
Hosrom, your car looks great, I was just curious. Good job on all the work, hope the car is running well.
#72
Is it your car in your avatar Hosrom? Why is you engine bay red in your pics?
#73
Hussam, If you use red color plugs and vacuum lines, you might get some extra HP. Everybody knows that red will give you more performance. I have painted all my engine bay contents red, look in my sig how much power Iam making mostly from the color change.
#74
Troll!
Besides BLUE makes more power, that is wht ATE has BLUE racing fluid, not red!!!
Don't hijack my thread!!!!!!!!
#75
Originally Posted by Karl2bdc
I'm sorry, but i can't believe dave is still selling that 1/2" blue hose for the brake booster line. There is a specific porsche hose with the proper bends in it that installs much cleaner. That 1/2" line is crap trying to make it fit without kinking. (funny thing is, i have seen a kit come from him with the brake booster hose, so why it isnt standard, i dont know). Also, toss the CV valve, install the boost controller. If you pull that cv mounting plate, just remember to add washers, or the bolts will bottom out before they get tight. Jack up the passenger side of the car, put a jack stand under it, reach under pull the old hose off the wastegate and install the new one that will run to the controller, shouldnt take more than 5 minutes.
~Eyal
