build my own boost controller...
Old 05-15-2006, 11:37 AM
  #121
toddk911
Drive-by provocation guy
toddk911's Avatar
J Chen:
So yo uahve the Reliaboost forst as your relief, and then the regulator correct?
Which regulator are you using?
Old 05-15-2006, 12:29 PM
  #122
DLS
DLS's Avatar
I´m thinking of building this, i have calculated the cost for it and it will cost me about 110$ in parts
But i´m thinking of skipping the one-way valve, i don´t think it´s necessary if i bleed out the air with the regulator. (there can´t be any pressure between the wastegate and the regulator if it´s connected so that it bleeds to the atmosphere)
Byt if you use a pressure regulator that cuts back the air not bleed out then you need a one-way valve to release the pressure between the wastegate and the regulator.
I hope that somebody understand my thoughts
Old 05-16-2006, 05:48 PM
  #123
Douglas Sorrells
Douglas Sorrells's Avatar
Well I reinstalled the one way valve this past weekend. It really seems to help the spool time between 2nd. & third, as in reduces that spool time to zero.
This is the setup as I have it installed now.
Old 05-17-2006, 10:43 AM
  #124
toddk911
toddk911's Avatar
So even with the Tial you noticed a difference using the check valve?
Are you running single or dual port?
Old 05-17-2006, 10:44 AM
  #125
toddk911
toddk911's Avatar
Doug: What gear were you in when trying to judge the full boost/rpm ???
Old 05-17-2006, 11:30 AM
  #126
J Chen
J Chen's Avatar
Hi Toddk,
I'm using a Japanese made regulator which has a built in
pressure gauge. The thing I like about it is that it is only
about half the size of the Norgren regulator.
Old 05-17-2006, 06:17 PM
  #127
jimbo1111
jimbo1111's Avatar
http://www.boostcontroller.com/index...6category%3D26
I think you guy's missed this. I posted it way back. This is exactly what your trying to build. Why would you want to build it for a $100 bucks when you can get it in such a small package.
Old 05-18-2006, 11:23 AM
  #128
Douglas Sorrells
Toddk911, Tial in single port mode, I would be rolling along in 2nd about 30 mph & floor the pedel and just let it build. I've got to take a video of how quickly it spolls to 20 now, it's unbelivable & yes even with the Tial. I am really amazed with it now, it's just incredibly quick. I am literally at 20 psi of boost in third as soon as I get my foot back in the gas after the shift. Zero spool time in 3rd.
jimbo1111
are you saying that that controller allows you to both control max boost level and also boost speed?
Jchen, How about some details/pics on the regulator your using? I'm interested to see.
Old 05-18-2006, 04:47 PM
  #129
jimbo1111
jimbo1111's Avatar
jimbo1111
Yes. That's exactly what I'm saying. It has a ball and spring in series with a bleed valve.
Old 05-18-2006, 05:12 PM
  #130
Douglas Sorrells
Well that is pretty cool then & Yea I didn't understand that. Do you know anyone that's used one?
Old 05-18-2006, 05:39 PM
  #131
Duke
Duke's Avatar
I have trouble understanding why anyone would pay over $100 for any MBC when you still have to deal with different boost under different weather etc. Say what you want about "ricers" but IMHO they don't cheap out when it comes to stuff like this.
It's about controlling your boost! It's pretty important stuff...
Old 05-18-2006, 08:07 PM
  #132
Douglas Sorrells
we have a pretty big engine, pretty small turbo.. whats up with all the lag?
waiting till about 3k to make any good power just dosent make sence to me..
autocrossing this car is going to require alot of shifting between first and second..
The cars has a manual boost controller (dual setting turboXS)
and an autothority Mass air and chips (but i dont know which, I am assuming autothority)
what is the CV? (my best wild guess is control valve?) But I still have no clue as to where that is or what it looks like..
Adjsuting the boost controller is really only helping me make more boost not much lower
I will pick up one of those tial wastegates asap
This is a post by missing2 who is using one of the turboxs controllers & he is complaining about lag? Anyone getting quick spooling results with the turboxs controller?
Old 05-18-2006, 08:34 PM
  #133
jimbo1111
jimbo1111's Avatar
No I don't. It is the same thing as what you have built.
I am a firm believer that the bleed type of boost controller is the best for a dual port wastegate. I will explain.
A dual port wastegate with a bleed type mbc that has a 1 bar spring will not bleed exhaust on buildup because boost pressure passes through the mbc to the top port of the wastegate and helps hold pressure down on the spring. the pressure that goes through the mbc gets added to the spring rate to maintain the setpoint. 14 psi sideport and 20 top port will give you 6 psi of clamping force above the spring rate. holding the wastegate valve closed with greater force than just the spring rate alone. The reason why you are seeing faster spoolup than some others here. Is because of the smaller turbo/turbine you are using. If you don't believe me try hooking up your wastegate in a dual port configuration. I will bet that you will get the same if not faster spoolup.
Something I haven't tried yet that I think will help on spoolup is to tap a port on the discharge of the turbo for the mbc. There is more pressure before the intercooler. This would help to have more pressure on the top port than the side port witch is manifold pressure. To4b's have a tap right on the turbo.
Plus: If by chance your line splits or something goes wrong with your regulator and holds back boost to the wastegate. I can bet that you will blow your motor from overboosting. In a DP configuration. If the line splits the spring will save you.
Old 05-18-2006, 09:03 PM
  #134
Douglas Sorrells
Actually any faster from the way it is now would be undesirable. It's now almost too fast as it is, but I would be intersted is seeing how it is supposed to be set up under the dual port mode? Do you simply hook the line from the boost controler to the top of the wg and a line directly from the intake to the side?
Old 05-18-2006, 09:06 PM
  #135
jimbo1111
jimbo1111's Avatar
Yes.
Quick Reply: build my own boost controller...
