there are 2 possible knock sensor locations in the head
... but only 1 is used. Does anyone have definite info on why the second one exists?
Factory experimentation? Did the location change for certain years? Which is recommended?
UAE Rennlist Ambassador
From what i understand, firstly the knowck sensor is not on the cylinder head, it's on the block. Secondly, where did you find the second knock sensor? did you see one in the car ? there is one that i know of
My fault, I thought it was on the head because you have to remove it to remove the head. I was mixed up.
I do not mean that there are 2 knock sensors, just two possible holes with the right thread next to each other, that the sensor could be mounted in. I am wondering if this was the factory figuring out which hole was best and never bothering to delete the second hole for production blocks. I think that is too bad if they only tried 2 locations.
Except all good manufacturers try many locations to find the ideal one for minumum noise max signal. The valvetrain making the same frequencies as knock sometimes. The 951 has individual cylinder tuning capability when it comes to knock. So location is pretty critical for this I would imagine.
I belive finding the individual cylinder is done by timing as Tom says. Yes noise is probably a consideration and therefore a position on the head is not ideal but I would be surprised if you were able to find very different signals in different parts of a homogenuos block.
Just speculation though.
Bengt
Bengt
