fuel pressure oscillation question
How stable should the fuel pressure be??
Mine will oscillate about 1 - 2 psi at Idle
in time with the injector pulses. Rev it and the pressure smooths
out. I dont have any excessive noise like the damper is bad.
I was just wondering?
No Vac leaks and the damper holds vacuum fine.
I have been trying to smooth out the idle and I notice the
oscillilation. Also notice a slight dip in pressure when the idle would
get rough. FPR is good, Injectors professionally cleaned so I wonder
if it could be the damper or my fuel pump.
Hi awilson40;
I have the same thing here. My fuel pressure is set to 45/46 psi and when on idle it oscillates maybe 2-3 psi. I have the Lindsey AFPR and the Lindsey (VDO) fuel gauge mounted on the fuel rail. I was also wondering about my dampener or fuel pump as i have so AFR issues (impossible to set up as it should) ?
My filter is about a year old...It may be normal, with all 4 injectors firing at once it could cause pressure to vary even with a good damper. To really smooth
it out I would think it would need an accumulator like the old CIS cars.
Here is a small video of my fuel pressure gauge when motor cold on idle. The fuel pressure is set to 45/46 psi. There you can see it oscillates between 40 and 42 psi...
http://www.asarus.com/divers/fuel_pressure.mpg (450 kb video)
