Brake Fluid Concern
UAE Rennlist Ambassador
Im going to replace the brake fluid on my car tomorrow. Question is, if i change brands (Ate, Fuchs etc...) would i need to bleed the clutch master and slave clinder as well or not?
Also, my ATE supplier said that if i use the blue brake fluid he said that i MUST change the brake line with SS ones, true/false?
Idiot told me that i would blow my stock lines due to the pressure
I knew it sounded bull.........just check with you (see what i go through
Thanks y'all!
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Thanks y'all!
The thing is, he's German and he was factory trained by Porsche (i think).
That is one of the reasons i left his business and went for a more knowledgable place.
s/s line dont actaully allow any more pressure, they are just the same spec lines with s/s braiding woven over it. The s/s is not there to add strength to the lines, its for decoration and helps corrosion prevention. A 50bar rated brake line thats standard and a 50bar rated brake line thats s/s will perform exactly the same.
