new engine no oil presure!!
#32
Originally Posted by Duke
Any details on the 3l turbo?
I think tomorow I will be ready.
I have a strange problem. The power steering resevoir is full of air bubles.
I turned teh steering left and right (but without tires on it) It is still the same. Either the pump is damaged since I started the car without ATF in it and run the engine for 1 min or it needs more time to bleed it.
Konstantin
#33
Keep turning the wheel all the way back and forth while the engine's running, that'll bleed the rack. After 5-10 times check the reservoir again, you shouldn't be seeing many or any bubbles any more.
Sam
Sam
