944 turbo Boost Curve(s)
Stock 944 with K26/6...
At what RPM do you get full manifold pressure under the following conditions:
1st gear from standstill, full throttle:
first to second gear shift at 5500 RPM, full throttle:
second to third gear shift at 5500 RPM, full throttle:
cruise 2500 rpm 3rd gear, then full throttle:
4th gear 2500 rpm cruise, then full throttle:
5th gear, 2500 rpm cruise, then ful throttle:
Also, does anybody have dimensions on the turbine wheel on this K26/6....I assume the exducer is somewhere around 2.1" or so with a major af about 2.4"
Thanks,
JK
Thanks,
JK
