Bad Heater Valve...How to change?
Rocket Scientist
Hi guys, I was told that I have a bad heater valve because I am leaking coolant on the bell housing. WHere exaclty is that and how do I change it? Thanks, Derek
UAE Rennlist Ambassador
Look behind the oil filler cap, near the braket that holds the O2 sensor and reference sensor. You shall find two water hoses with the heater valve. Simply undo the hose clamps and replace the heater valve.
Just remember to bleed the coolant system when your done (with the heater on at full).
Just did my heater valve on the '88 N/A. Only took me and my neighbor 10-15min start to finish. Of course, IIRC, there will be a few extra lines in the way on the turbo. Hopefully the intake manifold doesn't have to come off to do this. BTW, it's a cheap part, only $20. Change it before it busts completely like mine did, and spewed coolant and steam.
Rocket Scientist
Originally Posted by theedge
No the intake doesnt have to be removed. Drain some coolant to be safe, so you dont get more on the bellhousing. Coolant eats clutches
Spell Checker
Be very careful when you are replacing the valve. The firewall is just two pieces of steel pressed together. You can cut the **** out of yourself when you are trying to get the new one on. I was doing that and I started bleeding and I noticed red fluid everywhere. I was like what the **** is this red fluid and where is it coming from. Then I realized it wasn't any type of car fluid but rather andy fluid. :-)
