Turbo graph?
#31
Originally Posted by Chris White
Nothing personal Skunk, its just that past experiences show that the folks that are very good at what they do don’t mind explain the basis of their work, those that don’t are often (not always) just guessing and trying to sell their ‘secrets’.
I think that you will find the 944 engines are a bit different when it comes to high rpm VE. The original design of the cams and head were not set up for that - as noted by the pretty lackluster HP numbers – 147 from a 2.5 liter! My grandmother can do better than that for peak HP. The torque curve is a different matter – very broad and flat.
“I know all about snake oil...not much guessing either; what part of "I have done this on other engines before..not much R&D needed to make it do the trick in the 944" did you not understand?”
Um….the part where you offered up the results in a scientific manner.
Chris White
Chris White
#32
hello
a question for the experts:
Why do you have at 1.3 bar boost 20lbs/min and at 1.8 bar also 20 lbs/min
BUT you know the car makes at 1.8 bar (o,8 bar) more power than at 1.3 (0,3 bar pressure)
if you have at both boost levels same flow you should also have the same power ? ;-)
Konstantin
Konstantin
#33
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Skunk - Yep, I look forward to taking a look at your results – I do welcome any new developments / tweaks to the 944 series, I guess I am just to jaded by past miracles, who knows? – you just might have something – are you aiming these mods at the NA or Turbo engine?
Konstantin – I don’t fully follow your question. ?
Chris White - I am generally skeptical about everything!
#34
Hello
ok I try again
take a look at this graph
![](http://not2fast.wryday.com/turbo/maps/k26_map.jpg)
you have the same flow of 0,1 m³/s at 1.1 and at 1.9 bar boost
Same flow at two different boost levels.
Why do you have more power at 1.9 bar? since you have the same air flow?
Do you have the same air flow?
Konstantin
ok I try again
Konstantin
#35
#36
In defence to Skunk....
I paid good money for headwork from Lindsey Racing, with work being done to increase the velocity in the exhaust port. They would not tell me what was being done. When I questioned work being done to the ceramic port, all they would say is....the improvement was worth the cost. Go to Lindsey website and all you will find is your "snake oil" description. I am pleased with the headwork though.
#39
>>>you have the same flow of 0,1 m©¯/s at 1.1 and at 1.9 bar boost
Konstantin<<<
The answer is you don't have the same flow at two different boost levels. To acheive this would require two different motors (different VE, displacment, turbo, etc.).
Konstantin<<<
#40
At 1.9 you pack more molecules of air in that 625cc cylinder that you'd do at 1.1 due to it's higher density...all other factors the same. The air flow is the same (volume-wise..you still fill 625+cc's) but it packs more oxygen for a given volume. Then you can burn more gas,and have more power.
#41
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Hmmm….I am guessing that a few bits of info need to be put out there so that the compressor Isopleth can be understood.
First – how to use a compressor isopleth
Determine the flow capacity at a specific boost level for the engine in question – The example the Konstantin uses 1.9 bar absolute (.9 bar of boost). Then you can figure out the mass of air* that the engine will consume at different RPMs and plot this against the x and y axis. By plotting this out you will see how the performance of this compressor matches up with the intended application. In this case the compressor hits the following contours on the Isopleth –
3000 rpm – a little over 65%
4000 rpm – 70%
5000 rpm - a little over 72%
6200 rpm – 72%
This is a fairly nicely matched application.
To address Konstantin’s question a little more directly –
If we assume the same air flow (0.1m3/s) with one engine at 1.9 bar and the other at 1.1 (assuming they both have the same VE and rpm) the 1.1 bar engine would have to have 72% greater displacement. (if total air low is the same then larger less boost = smaller higher boost).
Just for giggles – the 1.9 bar engine used as an example in the isopleth would run the compressor at 70% efficiency @ a tad less than 4000 rpm. The 1.1 bar engine would be running the compressor at 50% efficiency (pretty crappy). In the end the 1.9 bar engine would be putting out more power at 4000 rpm due to its more efficient use of the turbo compressor.
It might make a little more intuitive sense if you look at the scale choice on the axis – cubic meters (this is assuming uncompressed gas) or kilograms – we are talking about the mass of the air not just the physical volume
* the mass (or uncompressed volume) of air used is based on the mechanical displacement of the engine x RPM x Volumetric Efficiency
Chris White
4000 rpm – 70%
6200 rpm – 72%
Chris White
#42
Skunk Workz, Referring to you comments to my post, I can see that you have a better understanding of reality than the thrust of my post. We are essentially saying the same thing. The continuous flow I was referring to was for the turbocharger itself not a turbocharged engine.
#43
