WBO2 reading 14.7 constantly
Problem solved! for Zeitronix support!
Last weekend I took out all the wiring and the O2 sensor. Visually inspected it, found nothing wrong (visually) and put it on the car again. The result was a bit disappointing. Stil 14.7:1 at the WBO2.
I mailed Zeitronix support and again within the hour received a response. He/she persisted that something with the sensor harnass or the RJ-45 connector was wrong and offered to test it for me. I had however had to send the harnass and the sensor to them (from The Netherlands).
I deceided to cut off the RJ-45 connector (and the surplus of wire I could do without) and put on a ndw RJ-45 connector. Et voilá, everything works as it should!
Zeitronix WBO2 kit is a great product with even better support!
