What are your boost patterns for you EBC users?
Just wondering if you hit max boost in all gears with an electronic boost controller and what the boost drop is if any in certain gears. I know some of this may relate to what turbo you have also as well as the WG.
Evil,
Which To4e do you have and at what rpm do you hit 15psi in 3rd gear. Did you have a manual controller before and did the Profec lower the rpm @ which you see functional boost (12-15 psi).
Thanks man.
Thanks man.
Russ,
I have an older Vetesse stage 2 to4e with quick spool. I did have a MBC and now the EBC. I have full boost (18psi) @ 3650 thats in 4th. I don't know about 3rd gear. I actually have'nt had the car out at 18 psi in a while so my brain might be rusty. I have been making new maps for 12 psi and 22 psi so..
I forget to easy..must be getting old...lol
Nothing varies with outside air temp, No spikes and yes I feel the responce is worth it.. I also run a 1 bar spring in my Tial Wg.
As far as alittle or alot, well? Its nice to have micro adjustments at you fingers verses a try and see. Its a nice gadget
