replacement air box / belly pan screws
I am missing two of the screws that secure the top lid to the bottom of the factory airbox. Also I am missing several of the little screws/funky washers/ and hardware for the belly pans out front
Other than the porsche dealer; is there a supplier for these?
Thank you..................
the shoulder washers are probably Porsche only, you can substitute 6mm fender washers. The shoulder is just to stop you from crushing the pan as you overtighten the bolts. Regular 6mm bolts will work fine for all the threaded holes. If you need the fasteners that hold the rear edge of the front valence to the belly pan you can use sheet metal screws and washers.
thanx for the feedback, was concerned about the special washers mostly and the airbox screws seemed to be non-standard as well, will have to see what lowe's or home depot have..................
