Engine removal from top. Bell housing?
Thanks Perry. I already removed the crank pulley. I think I may remove the bell housing for a little extra clearance. Besides the eight or so bolts, is there anything else that needs to be removed to separate the engine from bell housing. The starter and slave are removed, and the sensors will be once I can work on the car again.
I disconnected the exhaust from the downpipe to test pipe. Is that going to be enough, it looks like it will be a very tight fit? Did you need to remove the downpipe to turbo, or cross over?
4 bolts hold bellhousing to engine, but to get it off you also need to pull cliutch pivot pin to drop the fork out with it. You should be set exhaust-wise. I do remove the radiator, gives a very helpful amount of space.
Sam
Sam
You don't need to remove the bell housing. Espacially if you removed the crank pulley, you will have enough room to pull it out. You will need an engine hoist with a tilt mechanism, so you can tilt the engine back, and clear the cross member (which should be left hanging by the struts).
Thanks. Radiator is out.
Where is the clutch pivot pin? Not sure what that is.
Looks like I would need to remove my wastegate in order to get one of the bolts that attach the torque tube to bell housing. That’s why I though it might be easier to remove the bell housing to engine instead. If it's only four bolts, it should be just as easy, right? How difficult is it to remove the clutch pivot pin? I'll probably need to look at the PET diagram when I get home tonight.
Thanks Guys.
Thanks Guys.
The clutch pivot pin is what holds the clutch fork in the bellhousing. You can't get the housing off with the pin holding the fork in place. (rather, you are not supposed to)
Looking underneath the bellhousing, close to where the slave cylinder attaches, you should see a round plug looking thing with a notch out of one side and a threaded hole in the middle. This is the pin, and it is about 6" long. You'll need to thread a bolt into it and hook up some vice grips and with lots of luck, you can pull the pin out. If it won't budge, a little bit of heat and persuasion from a hammer should get it.
If you can see where the needle bearings wore into the pin, it's junk. Buy a new one with new bearings. If there are no markings, run it!
Good luck!
Good luck!
if you need a hand with the clutch pin, or bellhousing bolts, i might be able to spare some time this week so shoot me a pm
Thanks for the offer Andrew. I'll let you know. All that's left really is the bell housing and cross member. If it weren’t so cold last weekend I would have tried to finish the job. Hopefully next weekend it will be a little warmer.
Hey Man
Originally Posted by dualblade
ahahahahaha, welcome to the four worst bolts in the universe. well, they are kind of a pain in the *** to get off. i was helping skoot with a clutch job this weekend and they really are in like the worst places. just barely enough room to get a ratchet on them.
