Narrow band showing lean when car is hot
I installed a Autometer o2 gauge last month before I left for Taiwan. In the few days I drove it I noticed something strange.
After a 10 minute warm up drive, the first 2 or 3 WOT runs the gauge would show 1 or 2 lights in being rich, about 12.5ish. Indicating that the fuel mixture was at least close. I know it's not an acurate indication, but good as an idiot light.
But after that, each run would get leaner and leaner, untill the gauge would show full lean. I'm running 18psi chips, but even after I turned the boost down to 15psi the gauge results were the same. There is no pinging that I can hear.
I know that o2 sensors are effected by temperature, and the voltage output shows this. But I've never heard of it being this extream before. A fellow Rennlister sent me a link to this which show the relationship of voltage to temp. http://www.halmeter.com/Halmeter.img...0_Brochure.pdf
What do you guys think?
Is the the sign of a o2 sensor going bad?
Thanks again,
Jason
Thanks again,
Jason
Regarding your problem, i heard the good indication from the autometer gauge should be one or two lights in rich when WOT (after 2/3 runs to heat the O² sensor up). Can someone confirm this ?
How should it behave when the motor and O² sensors are in temperature and at idle ?
Here is how mine behaves : 500 kb MPEG file (the oil temp is disconnected)
Going with the pack
is quite monotonous.
More questions on this
Mine goes to 2 in the green in 5th, and is richer in the lower gears.
It idles at a dim last lean LED.
Partial throttle makes it go up and down though...
Whats mine doing?
Whats mine doing?
The O2 Sensor has to hit 600 degrees F before the readings are accurate.
I'll add, after letting off on WOT, the car goes lean (to the last red bar), and stays there on my autometer gauge, until I give gas. What's up?
