Rear Wheel SMOKE!!
Old 11-09-2004, 06:20 PM
89PorscheTurboMobile
89PorscheTurboMobile's Avatar
Default Rear Wheel SMOKE!!
Hi,
Just please don't flame or jump on me for this, but you know how in the "944 Turbo Meals" video that red 951 is burning out and releasing all of that white smoke from the rear wheels? Well, how can I do that, please label gas/clutch/gear positions in order to make this possible. The tranny has LSD.
Old 11-09-2004, 06:21 PM
CPTdooberhead
CPTdooberhead's Avatar
Put some bleach on your tires, then try it
Old 11-09-2004, 06:25 PM
RMills944
RMills944's Avatar
1. 2nd gear
2. rev to 5000 RPM
3. dump clutch and put foot on brake enough to keep it still.
4. Watch tires spin
5. Wait for big bang from back end.
NOTE: THIS IS EXTREMELY HARD ON YOUR CAR AND I WOULD RECOMMEND DOING THIS UNDER NO CIRCUMSTANCES.
Old 11-09-2004, 06:31 PM
PCinDC
Rennlist Lifetime Member
PCinDC's Avatar
Or, if smoky donuts will suffice:
1) Find enormous empty parking lot
2) launch car softly, less than 5 MPH
3) crank steering wheel to the left (or right I suppose it doesn't matter)
4) Floor throttle
5) Watch tires spin/smoke billow
6) replace bald tires
7) sell Porsche to someone who appreciates it
8) buy Mustang
Old 11-09-2004, 06:33 PM
Perry 951
Perry 951's Avatar
How to do it? - Lots of track time and autocross practice. Controlled drifting is not an easy task to master so practice in a controlled environment is a must. (along with nerves of steel and lots of guts)
What is needed to do it? - A well balanced powerful automobile and proper application of power.
Old 11-09-2004, 06:35 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
Yep, 944fanatic is on the right track. Rage2 did some difting without problems (he's pushing 460whp at 25psi or so).
Easy launch, turning left and full throttle is fine, just don't drop the clutch at high revs.........
Oh yeah, make sure you have some $$$ for new tires
User 41221
User 41221's Avatar
Step one, swap trannys with me, as you don't want/need an LSD tranny for your intended use. You want an open diff.
Step two, read some of the above directions, they are spot on.
Step three, same as Step 8 above... you'd really be MUCH happier as a jockey in a pony car.
Regards,
Old 11-09-2004, 06:57 PM
RMills944
RMills944's Avatar
You may want to change that to right incase he doesn't have the correct oil pan baffle.
Old 11-09-2004, 06:58 PM
hosrom_951
hosrom_951's Avatar
Top the oil level, make sure she's full (and a little extra wouldn't hurt)
Old 11-09-2004, 07:39 PM
rage2
rage2's Avatar
Something like this?
http://www.virgeweb.com/rage2/944t/951smokeshow.wmv
I was only pushing around 350whp on this clip at low boost. No need for clutch kick, or ebrake, just a good knowledge of car control. It's not really hard on the car, just the tires.
You need LSD to do it.
Old 11-09-2004, 10:16 PM
ilikemy944
Going with the pack
is quite monotonous.
ilikemy944's Avatar
I need LSD I pulled out on a road today, stuck it in second still turning...
I was trying only to accelerate, left a 50' black bark with the right tire instead... which in its own right was kinda neat, but not the point of my actions... Someone give me a LSD tranny
Old 11-09-2004, 11:08 PM
DDP
Rocket Scientist
DDP's Avatar
I was told right hand turns are what causes the bad bearing? Can someone please clear this up? thanks
Old 11-10-2004, 03:41 AM
hosrom_951
hosrom_951's Avatar
Damn it Rage, that was very nice your rear Koni's were at full soft right? and that was all in second gear as well?
Old 11-10-2004, 03:48 AM
NZ951
NZ951's Avatar
I dont mind the drifting, its a bit of fun... but cleaning your tyre of the side of your car sucks... as does the fact that tyres are not that cheap, and its a hassle changing them.
Old 11-10-2004, 04:13 AM
daniel951
daniel951's Avatar
i have this problem going in a straight line getting on boost. This is something i am saving up for now.
Quick Reply: Rear Wheel SMOKE!!
