Shop in the NE who'll sleeve an engine
Originally Posted by OriginalSterm
i thought there were sleeves in the stock block? or am i using the wrong terminology?
this isn't necessarily to increase displacement, we need to fix a horribly scored and pitted cylinder.
too deep to hone the cylinder, it's quite a mess in there.
Look back at ski's track car post there are some pictures and info there.
Originally Posted by Willard Bridgham 3
The engine is called a sleeved engine because the piston runs in a sleeve that comes up in the sea of coolant. There is no sleeve in the sleeve.
I'm not assuming you press one sleeve into the existing bore or "sleeve" that is already in the block.
Originally Posted by David Floyd
You can go 100.5 and 101.00 mm without sleeving with the piston set that ski and jwl used in there track car.
i'm pretty sure we still would have almost no compression on one cylinder. that's how deep the damage goes.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The cylinders in the block are an integral part of the Alusil casting. The sleeving process bores out the existing cylinders to accept a steel/iron sleeve that can be machined various diameters (requiring new pistons)
IIRC, the damage OS is talking about is going to require removal of the stock cylinder and replacement with a sleeve. He had some pretty badly damaged cylinders.
OS - are you going to do PCA or POC or SSCA racing with it? If so Chris can build you a 2.6L motor (see his sig!).
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Based on experience, make sure whoever does the sleeve work has done them before and has a track record to prove it. Machining is not too complex but everything has to be done exactly right for long term success. Consider using the new Darton sleeves which on the surface seem to be a better approach than the individual press in liners typically used.
#3 had a piston ring break, so the wall is scored pretty badly and there looks like either detination or the piston slapping against the cylinder wall as well.
