Replace Injectors?
Originally Posted by Gator_86_951
That place is hilarious. You can only imagine what the stores would be like going to Florida and being just up the road.
I have never made it in the risqué cafe before... Every time I get up there all I see is this double wide trailer and I start laughing to hard to make it through the door. Its so fitting.
Originally Posted by Karl2bdc
Are there internal seals then? I have replaced all the old rings and pintle caps, so i know those don't leak, but i think i am getting fuel leaking past the rings, which to me would indicate a leaking injector internally over time. I pulled the fuel rail, and turned on the fuel pump, and they did not leak at all, but i definetly have the smell of gas when i remove the oil cap.
Originally Posted by UK952
I used the Porsche kit, noticed the hats were taller and fitted them anyway, car seems to run ok but what problems should I expect?
Tony
Tony
I sent mine to http://www.witchhunter.com, when I got them back, they looked like brand new injectors. I would definately recommend witchhunter for injector cleaning/rebuilding services.
I used Marren Motorsports on my 928 and was very pleased with the matched set of 8 I received back. The car ran much much better and dynoed 20hp higher with that being the only change.
